Galaxy 2010 dash upgrade typ2 to convers+ 2010
gsmunlock
Vehicle: ford galaxy 2.0tdci 140hp 2010
Post by gsmunlock »
Hello. I swapped on my ford galaxy 2010 2.0tdci automatic gearbox IPC 8M2T-10849-HD(NVM ROM 0162, ROM level BD) to BS7T-10849-VF (NVM ROM 1218 , ROM level CE) . Donor IPC was taken from 2010 mondeo (like seller says automatic gearbox ) too. All works except airbag light on dash and of course other mileage . Have errors in IPC module only , here log.
===IPC DTC U0140:00-2B===
Code: U0140 - Lost Communication With Body Control Module
Status:
Module: Instrument Panel Control Module
===END IPC DTC U0140:00-2B===
===IPC DTC U0151:00-2B===
Code: U0151 - Lost Communication With Restraints Control Module
Status:
===END IPC DTC U0151:00-2B===
Question is it possible make it work as it should work or there are hardware difference and it is not possible.
Any help welcome. If it can be done so how? Does forscan will able do it with extended licence ?
smetin
Vehicle: Ford Galaxy mk3 2.0 tdci 2009
Re: Galaxy 2010 dash upgrade typ2 to convers+ 2010
Post by smetin »
Hi, I did have same issue with my Galaxy 2009 tdci. I 've installed a Convers+ from Mondeo 2010 tdci.
All worked fine, but airbag light issue and seatbelt warning activation/de-activation did not work :(.
The issue was caused to higher ROM level of Donor IPC..
It could be reprogrammed, for about 80 Euro's but I did'nt want to spend money for that.
I've changed the 2010 IPC with an 2008 model. Now I don't have the issue with airbag an seatbelt warning, it works fine.
did you do that
Asbuilt_BCM write to IPC
smetin
Post by smetin »
Asbuilt_BCM write to IPC?
No, I did not write anything to IPC.
I just installed the 2008 IPC.
your IPC still has the correct (your car's original) configurations data :?:
smetin
Post by smetin »
I have no idea about configuration data etc..
I thought replacing IPC was plug-and-play..but it seems to be not like that.
According to your reply, when IPC is replaced it must be configured/reprogrammed?
To do this,what do I exactly need?
-modified ELM327 for FORD
-FORscan
.. what more?
smetin
Post by smetin »
Last few days done some carefully experience with Forscan and ELM327 scanner with MS/HS switch.
I've backupd and saved settings from BCM and IPC.
The IPC installed did have of course the Mondeo settings from the donor Car.
I've backuped BCM and load it into IPC. When I read out the IPC, i've got now correct information (no more info about mondeo 1.8 tdci etc).
The only thing I'd like to have is 'parking brake applied' text with sound signal at the IPC. How can this be enabled?
The red light for parking brake applied is shown correctly like this, ((!)) But I'd like to have the textual warning and sound while driving the car.
thanks in advance for your reply.
snwaine
Vehicle: Ford Galaxy mk3, Diesel 2.0L, 2010
Post by snwaine »
Hi I am having the same problem with the airbag light, I have downloaded the as-built and added it to new cluster all the information on the new one says it's for my Galaxy but it's stall got the error.
Any help please.
Thank you.
P.S.
My original post
https://www.talkford.com/threads/instru ... de.407610/
My IPC as-built only has one entry is that normal?
heads or tails coin flip online
