PCM 2.0 130ps 2020 transit custom
Val33650
Vehicle: 2020 transit custom 2.0L 130 ecoblue
Post by Val33650 »
Hi everyone sorry for my english i’m french 😅
today I wanted to connect forscan on my truck and watch the pcm to switch my 2.0 130ps to 170ps.
the problem is i only have PCM AS BUILT and not just PCM how do I do that?
I have not yet found the codes to modify a 2020 transit if anyone has them by the way I want them pleaseee
Thanks for futur réponses 😉
Val33650
Re: PCM 2.0 130ps 2020 transit custom
Post by Val33650 »
hello everyone still no solution found 😔
if someone has the code list and the solution to go to 170hp 😉
malsat
Vehicle: Transit Custom 130 2021
Post by malsat »
I have a 2021 130 and want to change to 170 if anyone knows how please share
Val33650
Post by Val33650 »
Hey !
have you found a solution?
Thank
mschumiv
Vehicle: Ford Focus MK4 1.5L 88kw diesel 2019
Post by mschumiv »
This cannot be done with forscan alone. It's not like you just click an option and voila you have a more powerful engine. You need a proper firmware file to flash your ECU. You can find them online, usually for a price. The danger level is very high and i recommend this to be done in a shop with experience.
mschumiv
Post by mschumiv »
This is valid for all brands and models.
Don Ridley
Vehicle: 2016 Transit Connect
Post by Don Ridley »
mschumiv wrote:
Wed Nov 03, 2021 3:09 pm
This is incorrect. Search the forum and you will find some diesel models have the ability to switch between PS (HP) versions using Forscan. Apparently the firmware contains the code for both tunes.
The op in this post is trying to find out if this upgrade is possible for a different vehicle and model year.
davetcollection
Vehicle: Focus 2017 ST-Line 1.0 Auto 6F15
Post by davetcollection »
Hi, sorry I can't help, other than recommending you try UCDS??
malsat
Post by malsat »
Come on some one spill!
older models had it in PCM but not 2021 but It can be done,
theres even guys selling it.
smartguy69
Post by smartguy69 »
Have a look to see if you BCM Main Configuration like on Kuga and Focus. If so then look in engine and see if you have options.
