Transit custom 2017 2.0 ecoblue cruise control
metal_man
Vehicle: Fiesta metal
Post by metal_man »
Hi
I’m trying to retrofit cruise on 2017 transit custom 2.9 ecoblue
I have enabled cruise in bdycm
I have also enabled cruise and asl in the pcm and it doesn’t work
Is there anything else I need to do?
Nikolr1
Vehicle: Transit Custom 2.2 100cv 2015
Re: Transit custom 2017 2.0 ecoblue cruise control
Post by Nikolr1 »
hi i am trying to do the same on my transit custom 2.2 from 2015. Please can you tell me how you have modified the modules? In my connection with forscan, the "easy mode" does not appear, only "as a built"
metal_man
Post by metal_man »
For the 2.2 you activate cruise and asl in both ipc and bmcii module
Nikolr1
Post by Nikolr1 »
In case it works for someone, in my 2.2 model, activating the cc and asl in bcmii is enough.
metal_man
Post by metal_man »
im still having problem with sccm
the option i get are in pic and where Model is its says Fiesta
metal_man
Post by metal_man »
i would expect to see something like in this picture
metal_man
Post by metal_man »
the sccm module is apparently the correct one and is updated with the latest software GK2T-14C579-AF
metal_man
Post by metal_man »
Well after trying with forscan I couldn’t sort it, but ended up using ucds and got it working
The config for sccm is
724-01-01 = 0001 2E
