Acm problem after 4 to 8 inch upgrade
consp
Vehicle: Fiesta 125hp 2017 (My13.25 Mk7.5, With EU Sync3)
Re: Acm problem after 4 to 8 inch upgrade
Post by consp » Mon Jul 22, 2019 7:40 am
Yansel wrote:
Sun Jul 21, 2019 6:35 pm
after upgrade I had trouble with audio, volume wouldn't be as loud as before, bluetooth audio messed up with calls. Got it solved with these values.
try this ACM values:
727-01-01 920x xxxx xxx
727-01-02 x300 xx
Thank for the info but unfortunately there is no way to alter those values as in the Fiesta (at least) the configuration is not by AsBuilt for the ACM but by Central Configuration. The CC/IPC forces the radio to use a smaller format asbuilt (1 byte) without the options available. I have not been able to get it to report the extended format in any way.
consp
Post by consp » Sun Jul 28, 2019 7:49 pm
I figured out my problem: Bad connections
The APIM plug pins are about .2mm thinner than my measurement tool's pins which caused them to extend too far and make no or bad connections. Fixed this and the sound from the 'alert'/mono line is back again.
Settings are now which work:
112 - In car entertainment High level CD AM/FM
154 – Accessory USB without
157 – bluetooth Handsfree without or G2 bluetooth (makes no difference)
172 – Front Display DM8 with nav
214 – Mini ICP (08)
I changed the ACM value byte to 02 but this seems to make no difference but it was that on the car from which the Sync 3 device came from so I kept it like that.
tezza
Vehicle: ford focus
Post by tezza » Mon Nov 25, 2019 4:52 pm
consp wrote:
Sat Jul 13, 2019 4:01 pm
tried changing the bluetooth settings and got phone audio to not work again. After setting it back to known working settings it worked again.
In my case calls work with "157 – bluetooth Handsfree without" and "G2/3" (option 09 I thought). Option G1 will fail audio as it expects it not on the mono but on the Main channel which is incorrectly output by the APIM to the mono channel.
I might try one more thing to check if the APIM is outputting the nav sounds to mono in the "non working bluetooth" an see if any output occurs but I didn't have a multimeter at hand today.
Otherwise I guess I'll try updating the APIM again to the latest firmware and hope it resets the incorrect settings. I also got my hands on a VCM-like device and might check if the engineering mode on IDS might give some insight.
Been searching the net after i did the sync 4" to 6.5" sync2 on my 2015 fiesta all is working apart from the audio buttons on the steering wheel , is there something i have missed
Thanks in advance
consp
Post by consp » Mon Dec 02, 2019 11:43 pm
You need to configure the HW SWC and make sure the device is either set to C1MCA (EU) or CGEA1.2 (US). Otherwise it will most likely not work. Since everything else is working it most likely is set up correctly.
These are mine:
Code: Select all
#   -bits-loc- Name        - Field     // Mask  - Location in field  // current value(s)
12  - 2  - 14  CAN Steering Wheel Control Switches:  ............................................................. 7D0-01-01 // 0x03     nnnX nnnn nn // 0x68
                     >>    0:   Not Available (do not log missing messages - also HW SWC)
                           1:   CGEA SCCM (log missing messages against missed SWC)
                           2:   SWMT (ie cursors and OK button over CAN) - C1MCA and CGEA 1.3
                           3:   SWFC (ie has function buttons) - C1MCA
And
Code: Select all
51  - 2  - 58  HW SWC:  .......................................................................................... 7D0-01-02 // 0x30     nnnn Xnnn nn // 0x17
                           0:   Not Available
                     >>    1:   SWAC with volume, PTT...  (Variant C)
                           2:   SWAC with Mode, Seek, etc... (Variant A)
                           3:   Reserved
Are the correct settings for HW SWC (buttons) in the fiesta and transit courier in the EU at least. For US you mileage may vary but these settings control the buttons.
You have to match the location and the correct bits so the first one is the last 2 bits 7D0-01-01 byte 2. My value is 0x68 which with mask 0x03 result in (0x68 & 0x03) == 0x00. The other one is in 7D0-01-02 byte 3 mask 0x30 which in my case is (0x30 & 0x17) == 0x10
consp
Post by consp » Tue Dec 03, 2019 9:17 am
Thanks in advance
See post above (forgot to quote).
You can also check the following settings just to be sure:
Code: Select all
63  - 1  - 72  CGEA Version:  .................................................................................... 7D0-01-02 // 0x80     nnnn nnnn Xn // 0x42
		     >>    0:	CGEA Version 1.2(also set C1MCA)
		           1:	CGEA Version 1.3 (will implement new power moding strategy)
pvitulli
Vehicle: F-150, 5.0 , 2016
Post by pvitulli » Tue Feb 04, 2020 11:29 pm
I did 4 to 8 inch sync 3 upgrade. Everything worked except sound during phone calls.
I was able to fix it by reprogramming the ACM with Forscan. Here are the settings:
2016 Ford F-150 XLT
727-01-01 9800 1800 8060
727-01-02 0300 34
727-02-01 5B8C
727-03-01 1446
727-04-01 0003 0255 53E0
