2016 Ford Focus will not connect to BCM (AS BUILT)
Neo1130
Vehicle: 2016 Ford Focus ST
Post by Neo1130 »
Hey all,
I am getting a problem. I am trying to access my BCM (AS BUILT) section to do some programming on my 2016 Focus ST. After I try to connect, it will reset the car and a message comes up saying that the procedure was cancelled and everything stops.
I have the most recent drivers installed and using the recommended OBDLink EX. The USB port I believe to be a 2.0 as my 3.0 ports are color coded.
I can connect just fine in Focccus to change parameters there.
Don Ridley
Vehicle: 2016 Transit Connect
Re: 2016 Ford Focus will not connect to BCM (AS BUILT)
Post by Don Ridley »
Try deleting the vehicle profile and have Forscan create a new one upon start-up.
Neo1130
Post by Neo1130 »
Thank you. I will give that a shot. I had the latest version installed and all that before I ever hooked up to the car. Only thing that changed was going to the extended license version.
Don Ridley
You need internet access during the SBL download process. Make sure you have a good WiFi or other connection.
