ABS bleed without pressure bleeder
F0l2saken
Vehicle: 2007 Ford Escape Hybrid
Re: ABS bleed without pressure bleeder
Post by F0l2saken »
I tried using a Mitvac 6400 power bleeder, but it couldn't do more than 22PSI before releasing pressure. I tried doing this to pressurize the system and then run the test, but it's the same result each time, it fails.
I've now replaced the HCU 3 times with 3 working ones on this 2007 pile of ford junk, took it to 4 dealerships after replacing it and properly flashing the vin onto it, and 4 dealerships couldn't bleed it as well.
Off to the junkyard it goes, a perfectly working hybrid vehicle with 170k miles on it with no issues but the worst braking system ever designed by any company.
Never again, last ford I will ever own.
hueypilot
Vehicle: 2017 Ford Police 3.5L
Post by hueypilot »
Information on bleeding brakes on the hybrid.
27285.pdf
(195.25 KiB) Downloaded 98 times
