Clear Crash data using ELM327
denbo
Vehicle: ford focus 16 zetec
Re: Clear Crash data using ELM327
Post by denbo » Mon Nov 20, 2017 5:58 pm
Lets get this clear... You CANNOT clear crash data with Forscan. You can reset... but that is a different thing altogether.
Paxtonix
Vehicle: Ford mondeo mk 4
Post by Paxtonix » Sun Dec 17, 2017 8:10 pm
Hi guys.. Long time not here.. :D sorry for that :D
denbo wrote:Lets get this clear... You CANNOT clear crash data with Forscan. You can reset... but that is a different thing altogether.
That is very helpful so I will try it other way around with bench.. Any one have the clear epprom file so I can flash it to the RCM memory ? or optionaly can I dig the data out and than change the parametr in hex that is giving the rcm mem full ? or shall I just wipe all data from crash mem ?
asking coz I do not have the RCM on my table so I do not know how the PCB is constructed and how many memory chip they have.
william wrote:Here's what ford say about the dtc.
DTC U1A37 00: Crash status telegram *RCM crash data. *Clear the data memory using the Ford diagnostic equipment. REPEAT the self test, CLEAR the DTCs.
I believe that it is only possible on FL cars. have studied this thred for so long. Authorized service always force to buy new module. Or fuckers delete the data and charge you for module change ( also possible)
Found some PCB's fotos for restrain module but according to them there is no memory chip ? looks like relays only , where to search for memory then
....kekko91...
Vehicle: Ford fiesta mk7 1.4 TDCI
Post by ....kekko91... » Sat Feb 24, 2018 3:16 pm
ok, so the only thing i can do is to clear the ecu with bench method. I will do this at a professional technician.
Do you know if is necessary replace the airbag sensor? In my case my car had got a front end damaged and i see a sensor near bonnet latch
denbo
Post by denbo » Sun Feb 25, 2018 10:21 am
KEK ...no the crash dump is full. It needs to be clear dump with programmer
loscalpello
Vehicle: Focus 1.6 tdci , engine HHDA/90hp,2009
Post by loscalpello » Fri Mar 02, 2018 10:24 am
FORScan wrote:Crash event has to be reset using service function "Crash Flag Reset" in FORScan. The function is available only for European models. For Mondeo 4, Smax and Galaxy crash has to be reset in RCM, then (if necessary) in BCM module. DTCs must be cleared after crash reset. Using service tool, crash can be reset up to 5 times, then RCM module has to be replaced or cleared directly in EEPROM using special equipment.
It's correct ;-)
Baarnnz1990
Vehicle: Ford Fiesta MK6
Post by Baarnnz1990 » Sun Jul 14, 2019 1:36 pm
Managed to do crash flag reset in the service functions on ford fiesta 2013 sline. Then cleared codes and turned engine off drove for a while seems fine.
tonymtz1
Vehicle: Mustang 3.8, 2002, V6
Post by tonymtz1 » Sat Sep 07, 2019 11:39 pm
I have a Ford Fiesta 2013, Steering and knee airbags deployed. I replaced them as well as sensors. I need to do a crash reset, how can I do this? Thanks in advance!
Vehicle: *** Ford ***
Post by f-wolf » Sat Sep 07, 2019 11:52 pm
tonymtz1
Post by tonymtz1 » Sun Sep 08, 2019 12:07 am
IS there a way to do this with forscan?
Finneagle64
Vehicle: Ford fiesta zetec s 1.6tdci 90ps 2009
Post by Finneagle64 » Thu Sep 12, 2019 11:23 pm
Hi all, i recently replaced all airbags and the airbag module and all the dtc codes have gone and there is no crash data but i am still getting one more code which is U2012:95 - Car Configuration Parameter(s) and it says its to do with the restraint control module, incorrect assembly. Can anyone please help me fix this as its doing my head in!
Thanks in advance!!!
