Method to disable auto stop / start found
Airborne_Ape
Vehicle: F150, 3.5 Eco, 2017
Post by Airborne_Ape » Tue Mar 07, 2017 7:17 am
I'm sharing my test with the rest of you to use as a exactly that; a test, I can not guarantee anything.
All I can say is I figured it out on my 2017 F150 and it hasn't exploded yet.
2017 - F150 - Lariat 500a
Try at your own risk:
https://youtu.be/FQEn8U6A024
To summarize, I think a 100% auto stop/start disable would look something like this (I left my IPC stop/start message center enabled so I can still monitor it):
BCM 726-48-02 x0xx xxxx xx
FCIM 7A7-01-01 xxxx x0xx xx (optional - disables switch)
IPC 720-01-01 xxxx 1xxx xx (optional - disables stop/start message center on 2017 F150)
Please confirm if you encounter positive results in other Ford: vehicles, trim or model years.
gt_stang
Vehicle: 2016 Mustang GT
Re: Method to disable auto stop / start found
Post by gt_stang » Tue Apr 04, 2017 5:07 pm
What was your default value for IPC 720-01-01 xxxx 1xxx xx? Trying this on a 2015 Mondeo.
Airborne_Ape
Post by Airborne_Ape » Sat Apr 22, 2017 6:10 am
My original IPC values for 720-01-01 were: 2C0B 3064 70
Sorry for the late reply.
gt_stang
Post by gt_stang » Fri Apr 28, 2017 4:30 pm
Thanks. Is this "restart safe"? Does changing BCM value set Auto start/stop feature permanently or is it just the value when it's deactivated via IPC?
jfjk
Vehicle: F150, 5.0L, 2015
Post by jfjk » Sun Aug 13, 2017 4:02 am
If you change only the BCM 726-48-02, is it permanently disable or it come back if you press on the switch again???
Thanks.
Airborne_Ape wrote:I'm sharing my test with the rest of you to use as a exactly that; a test, I can not guarantee anything.
buzzkc
Vehicle: F150, 2.7L Ecoboost, 2017
Post by buzzkc » Tue Aug 15, 2017 3:35 am
Used BCM 726-48-02 x0xx xxxx xx on my 2017 F150 XLT 302a. Worked like a charm.
The code disables the function all together. You can press the switch and it lights up as off or again to back on, but it still doesn't allow the auto S/S to work. The symbol on the dash display shows with a line through it as if one of the parameters for it to work isn't available, but only when the button has be turned off and back on, as if it's trying to work.
Broncocrawler75
Vehicle: 2016 Ford F-250 6.7
Post by Broncocrawler75 » Tue Feb 06, 2018 5:12 pm
Used the BCM code 726-48-02 x0xx xxxx xx and it worked on my 2015 F150. Will be trying it on a 17 and 18 in the next few weeks.
xjeepguy
Vehicle: Fusion EcoBoost 1.5 2017
Post by xjeepguy » Thu Feb 15, 2018 12:04 am
This worked nicely on my 2017 Fusion SE 1.5 Ecoboost. No more stop/start. Thanks!!
giando87
Vehicle: Focus ST 2.0 ecoboost 2016 year
Post by giando87 » Fri Apr 27, 2018 5:44 pm
Hi, someone know if it works on Focus st 16?
sist
Vehicle: Mondeo 2018 2.0 150
Post by sist » Fri May 04, 2018 5:16 pm
has anyone ever tried the pscm 730-01-03 to disable start / stop?
